Headlight globes what to get???
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mcvk, Jul 26, 2008.
  1. mcvk
    mcvk New Member
    Newcastle
    VS Executive V6 Auto
    My headlights are getting a bit dull so I will be getting some new globes.
    I wan't to get Philips globes, but there are heaps of different types (blue vision, crystal vision,x-treme power). What are peoples thoughts???
    Also what is H1 H3 H4 H7 etc???
    Is there any reason to go HID???
    Thanks in advance
  2. greenacc
    greenacc Searching for the billion
    VE Berlina
    far as I know H1,2,3,4 and so on is the size/shape/power draw of the globe ?. you have to get the right one or you will have problems. VS use H4. I wasn't happy with the standard globes in my VS go i fitted Narva plus 50's. They are supposed to be 50% brighter than standard and are the same colour and same temperature. I didn't want the try hard blue ones... It's hard to say if they are really 50% brighter but definitely made an improvement. Some globes run hotter than others and can melt your headlights , so check that out before you buy.
  3. PRH
    PRH New Member
    Mildura Victoria
    vp s utility,and a KENWORTH
    G'day,H1-2-3-4-7 ect are the type of mounting ect on the globe,the 55 w is the amount of power it draws,a H 4 60/55 is the headlight hi/lo beam globe,
    as far as not wanting to replace the globes with philips,IMO they are about the best to get,i would'nt put a bloody narva product on a wheelbarrow.
    I know thats what a lot of places only sell narva but as an auto electrician i steer away from the stuff coz i have found that it is'nt as good as the others.
    Phillip :wax:
  4. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    Philips Blue Vision all the way, I've had them in all my cars, including two VS commodores. They are a nice white light, and they are fully road legal, UNLIKE the Diamond and Crystal vision lights, which whilst they are more blue in colour they actually throw less light on the road.
    For a VS you'll need H4 bulbs for your main Low beams, and for the inboard Hi Beams you'll need H3 bulbs.
    HID are very good, but you need to spend a lot of coin to get them, and they don't look good in normal lenses, you need the projector type ones.
  5. Muzz-VS
    Muzz-VS careful im very fast =]
    Victor Harbor, South Oz
    VS Stato 5L
    lights
    i just recently bought the blue vison ones nd they are the way to go everything is so clear nd high beam is frikken decent lol u can buy the diamond visin nd the next ones up watever they are but they dont last the legal amount of time so u can get defected lol but yuu wont, the blue vision ones set u back 40-50 buks nd the diamond vision goes upto like 100 buks so i recomend just going blue vision.
    'Muzz'
  6. strikewon
    strikewon New Member
    MELBOURNE
    Commodoer VS Executive II V6 3.8L
    do they work well thru fog and rain conditions...if so ill def go with blue vision...let me no asap...cheeers
  7. RX25SE
    RX25SE Real cars are steel cars.
    MY07 Liberty 30R Spec B 6sp wagon
    I had some type of blue globes in mine.
    Worst effen puss infected pieces of cr@p globes I have ever had.
    First thing I did (day two of owning car) was rip them out. Fitted phillips +80. Hundred times better.
  8. Kurtp
    Kurtp VR Buicks > You ;)
    Pakkey VIC
    VR Series 2 V6 Sedan
    Strikewon: I know for a fact the blue lights are SHITHOUSE in really foggy conditions, they make it heaps worse.
  9. RX25SE
    Strikewon: I know for a fact the blue lights are SHITHOUSE in ALL conditions, they make it heaps worse.
    FIXED!!
    Blue light does not penetrate, it scatters. (Thats why the sky is blue kiddies :) )
    Normal light globes have less blue light (ultra violet) and more red light (infa red) so it will penetrate better. This is why you can see in the dark using infra red.
  10. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    The Kelvin factor does change the visilibity, 3000K being the best type of light to see in, blue lighting is a gimik all blue lighting will do is glare the driver coming in the oposite direction and overall is only for rice factor, the colour blue is the hardest and slowest type of light to see with the human eye.
    If you want lights you can see well with and also work best in fog stick to 3000-4000k bulbs with clear glass, no blue coating. I use 4000K blubs for low beam and 3000K blubs for high beam.
  11. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Go Phillips Xtreme Vision. Best globes I have ever bought. Crisp white light that is bright in all conditions. Have them in my VR and they are 150 times better then standard.
  12. GMH95
    GMH95 Sorry I dont do Resprays
    Western Suburbs
    VS Berlina S1 3.8l
    phillips blue vision best globes for the best price and no there not blue they are more of a white colour
  13. The1
    QLD
    VS V6 Berlina Auto
    There 4300K i believe so not blue.
