Headlight not working but the globes good?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Stef-vy, Oct 9, 2018.
  1. Stef-vy
    Stef-vy Member
    Hobart
    Vx 02' + 97 vt commodore
    Hey guys, I have a vx 2001 and it has Monaro headlights and tailights, no issues with the back but front headlight on the left side has completely killed both of the normal driving lights in only the left side, but it still works on high beam? I'm confused and worried it's a bad wiring connection or something because the globe seems undamaged
    Am I using wrong globes? The current light that isn't working is H1 12v 55w The car was a complete mess when I first got it this is about the last issue left to fix.
    Photo of the globe is a bit blurry but you can tell it's still a good globe,
    Anyone who could help is really appreciated ☺️
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Have you checked both headlight fuses in the engine bay?
    It isn't clear whether this is a recent occurrence or if they have never worked?
    Stef-vy likes this.
  3. Stef-vy
    Stef-vy Member
    Hobart
    It was not working when I first brought the car, I changed the globes and it worked well for about 3 months and now this has just happened over last 2 days.
    Also this is the other second light that is in my left light (the left side,broken one)
    Also thank you I will check those fuses first thing.
  4. greenacc
    greenacc Searching for the billion
    VE Berlina
    Not sure what you mean it's still a good globe. Have you taken one of the globes that stopped working on the left side and put it in the right side?
    What brand globes are you using- sometimes the cheap no name ones blow very quickly.
  5. Stef-vy
    Stef-vy Member
    Hobart
    I mean the globe is not blown only one of them is. They are GE brand and I have not yet done that test but thank you I'll also test it that way.
  6. Stef-vy
    Stef-vy Member
    Hobart
    Thank you for the help.
    The problem is solved, put a different relay fuse in and the left light is now working again
    accentstencil and losh1971 like this.
