Headlight swap
MY18VF2SV6TTAN1C
Timaru, New Zealand
VF2 Commodore SV6 3.6L
Since the search function seems to be playing up I’ll ask here. Can I put SS-V projector headlights onto my Omega? Do they have different plugs?
Skylarking
123
Downunder
Commodore Motorsport Edition
Not sure as the shape may be subtly different between the two. Doubt they’d have different steel (fender, hood) pressings so you may need to simply change the grill between the lights. As to the plugs, both have H4 halogen globes, if I’m not mistaken, which defines the connector type used.
Alternatively you could look at caprice headlights as some came with HID options. You’d need to bring across the front and rear height sensors, self levelling module, headlight washer system and wiring but the HID lamps would be miles better (and almost fully compliant).
Maybe a visit to the wreckers would be in order ;)
MY18VF2SV6TTAN1C
Timaru, New Zealand
Cheers, I will have a visit to a wreckers this weekend. I’m in New Zealand so no headlight compliance issues, other than not being allowed red lights at the front for obvious reasons lol.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Xplaya
NZ
HSV
Yes indeed they do. Hoping the SSV projectors will just be a straight swap
if you have a series 2 Omega then they wont fit flush if it's a series 1 headlight. 99% certain will be straight swap with the loom side. I have a set of HSV headlights (They the same headlight as SSV / CalaisV) at the moment on my desk I can try get some photos if need
Fu Manchu
WA.
They are the same in every way other than the internals.
S1 only fits S1 and S2 only fits S2.
MY18VF2SV6TTAN1C
Timaru, New Zealand
Yep it’s a series 1 so I’ll start hunting. Good to know they should be a straight swap. Cheers
Skylarking
123
Downunder
Pretty sure every VE variant used H7 lows and H9 highs...
You’re correct. VF is also H7, H9.
I was going from memory based on what I’ve read here and it’s been rather fuzzy due to head cold. Sorry to OP for misinformation :oops:
