Headlights for SV6 Series II?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by brad2012, May 21, 2012.
  1. brad2012
    brad2012 New Member
    Perth, WA
    SV6 VE S2
    Hello,
    I have been searching everywhere for SV6 Series II LED headlights but not having much luck. Only headlight upgrades I can find are HID's but I am noticing a lot of people saying that they are illegal to have without certain conditions being met? Is there anywhere which sells headlight upgrades (preferably with LED's) for series II?
  2. Rxd
    Rxd New Member
    Newcastle, NSW
    VE Ute
    Do you mean the headlights with DRL's built into them?
    Just my 2c - I used aftermarket headlights in my ute. I've now gone back to the OEM ones since they were sunburnt after 4 months, if you're after more light perhaps look at getting some phillips "extreme vision" bulbs.
  3. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    Hid upgrade is ok. Just make sure they are aimed properly and you use 6000 k globes so the light is still a white colour
  4. BigBoss
    BigBoss Active Member
    VE Omega
    Mate you should really use projectors if you are going HID, I don't think there are any DRL headlights for S2 yet but i could be wrong.
  5. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    5000K is better if you want WHITE.
    6000K is starting to be blue-ish.
    Personally, I prefer 4300K which is brighter than both of the above and only has a minor yellow tint.
    As said though, HID upgrade is illegal. If you use the projector headlights, the HID works properly but it's still an illegal mod so you COULD get defected. I have them in my car and haven't had a problem though. If you want to stay legal, then Philips 'X-tremeVision" are regarded as the best mainstream bulbs.
  6. BigBoss
    VE Omega
    If you get HID get 50w High beams and 35w for the lows, Oh and get the newer digital "slim line" ballast units.
  7. brad2012
    brad2012 New Member
    Perth, WA
    SV6 VE S2
    Thanks for the replies
    Is there any place in WA which will fit these lights properly that you know of? I'm too worried I'll have it the wrong height and get defected =\
  8. Ryzie.
    Ryzie. New Member
    Perth, WA
    VE SV6 Commodore
    As long as you have them in the SSV headlights and they're not hitting people in the eyes; you'll be fine :)
  9. brad2012
    brad2012 New Member
    Perth, WA
    SV6 VE S2
    Where can I get SS-V headlights for series 2 SV6 VE?
  10. Diesel_junkie
    Diesel_junkie New Member
    New South Wales
    VE SS
    Being illegal if you go 8000k and aim them up too much mate I've had 6000k hid on my ss with normal lenses for 12 months NEVER been flashed once and police Haven't said or done a thing keep yellow Parkers to blend out the color a bit.
    Sent from my GT-I9210T using Tapatalk 2
  11. Diesel_junkie
    New South Wales
    VE SS
    Also there are integrated ballast hid kits for ve on Ebay no ballast or wiring needed the ballast is screwed into where the dust cover used to screw in.
  12. BigBoss
    VE Omega
    If you have the extra cash they^^^^ are the way to go
  13. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    The yellow doesn't "blend out the colour a bit" it makes the HID look even more blue and the parkers look even more yellow. That's exactly why I've been through 4 difference sets of LED parkers to find some that match the HID and not make my headlights look half completed.
  14. SV6GUY
    SV6GUY New Member
    VIC
    MANUAL VE SV6 S2
    i've been looking everywhere! cheapest i've seen is $700 a pair
  15. Diesel_junkie
    New South Wales
    VE SS
    Bullshit! I have my factory Parkers still doesn't make the HID stick out like dogs balls and that's what you want when you don't have projectors! Your worrying too much just get the integrated HID kit 6000k off Ebay 130 roughly for low beam and 150 roughly for high beam. If your paranoid either don't do it or get projectors but as I said not one single car has flashed me since I put them in about a year ago. They look sexy specially the high beam and the stock Parkers are barely noticeable not worth changing if anything makes the white light appear to be like halogen diamond vision. Someone should be able to provide you with a link to Ebay but type in 6000k HID kit ve commodore.
  16. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    Sorry, I was comparing my projector HID with stock parkers. I'm sure it would look different with no projectors and all your light flaring :thumbsup:
  17. Diesel_junkie
    New South Wales
    VE SS
    Lol light flaring my lights are fine. Look good better light zero issues.
  18. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    Unfortunately, I've never seen a HID kit put into stock reflectors and not have light flaring so I find it hard to believe. If you don't get high beamed, who cares, right? :)
