headrests..how do i getem off????
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by 31wgn, Nov 20, 2007.
  1. 31wgn
    31wgn New Member
    vr statesman
    i cant sm to get my headrests off,ive had the back of the seat off and everything?
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    They are not supposed to be removed - many have tried before and failed.
  3. 31wgn
    31wgn New Member
    vr statesman
    well im cutting thm with a hacksaw
  4. Cheap6
    Cheap6 New Member
    VP Exec
    Whoa! That's pretty drastic. I have some recollection that you can get them out by putting a pin/nail/small Allen key into a hole on each side at the top of the seat backrest but I was waiting to have a look on my own car before posting.
  5. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Choose a 24 teeth to an inch blade.
  6. Cheap6
    Cheap6 New Member
    VP Exec
    OK, forget the pin/nail idea. I dug around in my "personal library" and found two methods:
    1) Remove the seat back trim to access the retaining clips and use a small screwdriver to release the retaining clips.
    2) Cut two strips ~80mm by 15mm from a soft drink can and shape them to fit around the headrest supports. Lift the headrest up and slip the strips down between the ratchet notches and bump the headrest down, the idea being to put the strips from the can between the headrest support and the ratchet. Lift the headrest out.
  7. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    heres the way i do it.
    1. Push down on the upholstery near the head rest supports to release the upper head rest
    2. push the spring clips away from the head rest supports to release the head rest
    3. remove the head support from the seat back by pulling up
    have fun
  8. hako
    Toowoomba SE QLD
    VS11 BT1 V6
  9. nugatory
    nugatory New Member
    VS Executive S1 Station Wagon
    lol! that's the spirit!
    it's amazing what info comes out once someone brings out a hacksaw ;)
  10. protossw
    protossw New Member
    VR 3.8 EXECUTIVE
    i also tried but failed. cheap6's way should work
