heater/aircon fan stopped
sniper48
vs executive
Hi guy,
yesterday my blower fan in my 96 vs stopped. It has only had 1 speed for a while. 1.2 and 3 didnt work only 4th speed worked then it stopped. If i press the aircon button the green light turns on but the fan wont. I checked the fuses and they are ok..
Any help would be great as its getting pretty hot down here in Tassie.
BlackVXGTS
Melbourne, SE
Speeds 1, 2 and 3 work off the fan resistor, so it's almost certainly faulty. Speed 4 works directly off the blower relay (No.K) located in the relay housing assembly which is located in the engine compartment. The relay housing is attached to a mounting bracket on the driver's side strut tower. You may have damaged the fan motor by running it on high speed for too long, or maybe the relay is damaged. You could try swapping it with another relay of the same type to see if the relay is the problem.
