Broken Circuit Board
If you cooked your circuit board when you removed the MOSFET, or broke it trying to get it out, dont dispair. You can make a new one easily, for about $20. $1if you already have etchant and a bit of single sided blank circuit board. You will need the following, all from Dick Smiths,
1. Blank circuit board, cut a piece, 35mm x 24mm.
2. Etchant (about $15, the most expensive bit!)
3. Circuit board pen ( I just use liquid paper pen/bottle)
4. 220 ohm .25w resistor (240 will do if they dont have a 220) 6 cents.
5. 1W Zener Diode 33Volts. (z3515) 40 cents
6. 0.27microfarad capacitor (an MKT 63VDC will do, R3030) 45 cents.
7. Modlers brass tubing (1.6 mm (1/16))
You will need a soldering iron, and solder. Dremel or small grinding tool with a grinding bit, small circular saw bit, 1mm drill bit (Dick Smith also sell these, pack of 10 assorted sizes for about $10). 1.6 mm drill bit Or 1/16.
Cut out a bit or board, 35mm by 24 mm.
Use grinder bit to cut notches on top and bottom edge, so board fits into heatsink. Cut notch down right side to see MOSFET legs and brass tubing. Draw circuit onto board with etch resistant pen (liquid paper) and etch board. Drill out component holes with 1mm bit or (0.8). You will also need to drill a series of holes where the 6mm wide brass connector pins go, then make the slots with file or engraving bit in the Dremel. Alongside of the connector brass pins, drill three 1/16 holes. Slide through three pieces of 5mm brass tubing. Solder in all components, brass connector pins (that connect to the vehicles plug) and the three bits of tubing. Screw in the MOSFET. Bend up the legs at and angle then the last 6mm at 90 degrees the to the MOSFET and separate them about 5 mm apart. When the circuit board is placed in the heatsink, the MOSFET legs should slide into the brass tubes and you will see from above that the legs are correctly in each of the tubes and visually from the gap on the side of the circuit board. You can solder the MOSFET legs into the tubes if you like. I didnt bother, making the MOSFET and five minute job to replace in future
