Heater Controls VS series 2
VS Work Ute
52
Ballarat
1997 series 2 VS V6 ute
Hi all, Just had a roadworthy check and the fella said the fan isn't changing to the screen. He said the controls are vacuum operated. I have had the engine out and in recently, does anyone know which vacuum line goes where, in case I stuffed it up?
losh1971
North Tas
VE Series I SS Ute
AFAIK there is only one back line to the controls from under the bonnet. If it is off then it should only blow on feet. Check the y joint near the TB also check the line to the vac ball under the guard.
VS Work Ute
52
Ballarat
Cool which side guard, What is AFAIK? And TB?
losh1971
North Tas
VE Series I SS Ute
As far as I know. Throttle body. Left guard
losh1971
North Tas
VE Series I SS Ute
I'd start at the TB as that y piece are easily broken. A slight yank on the hose is enough to snap them.
jeepster
WA
VSII Ute
If the hose under throttle body comes off, you often hear a whistle. I think that one goes to purge valve. There are 3 hoses at back of intake manifold on Ecomoo. One big one for brakes and 2 little hoses.
VS Work Ute
52
Ballarat
Cheers, one little hose goes straight to the firewall. I took him off and plenty of vacuum at the manifold, so I'll have to investigate that one. It has a round plastic element, for no better word in that line... what does it do?
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
It's a "One Way" valve.
VS Work Ute
52
Ballarat
Got it sorted, the vent control had a broken clip through the center of it and the unit jumped it's lug and gave limited vent control. I was able to put a small screw through the center to replace the broken clip and she is working well.
