Heater front sides issue
aboody084
39
ksa
Ve S2 2011
Hello all
need an advice about what would be the issue in my ve 2011 s2 when I turn the heater on one side is heating and it becomes hot and other side is normal ...!!
Fu Manchu
WA.
Do you have dual zone climate control?
It is only just cropped out of the image.
krusing
Melbourne, Bayside
Goin by the image,
You have Dual Zone [system] activated, but Air-conditioning is turned off,
Press the Zone Button and it will change from "DZ" to "SZ" [Dual Zone to Single Zone]
Then press the Air Conditioner Button to turn the A/C on, select "SZ", then adjust the Temp accordingly,
If that doesn't work,
Reset the HVAC system,
If that doesn't work, as Fu Manchu mentioned above, there could be issue with one of your actuator's.
aboody084
39
ksa
Ve S2 2011
Goin by the image,
If switch on the air condition button the air will becomes cold and i already changed to single zone and the same issue one side is heating and the other is not .
aboody084
39
ksa
Ve S2 2011
aboody084
39
ksa
Ve S2 2011
VS_Pete
Donating Member
Try this.
Relearn Air Actuators
Have Air Con off.
IGN on, push and hold the rear demist button for about 5 seconds, you should hear all the actuators start moving.
krusing
Melbourne, Bayside
Remember to turn the rear demister off, if you happen to turn it on.
