Heater pipe o ring
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by tezza, Apr 28, 2008.
  1. tezza
    tezza New Member
    VX SS
    Hi all,
    Im just putting the tensioner back on my VS although its leaking where it goes into the water pump (pipe which runs across the tensioner assembly.
    Ive put a new o ring on it. Should I put some silicone or similar on it to seal it up?
    Thanks
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I'd put silicone (not RTV silicone) grease on it only to allow it to slip in easily and seat properly. Failing that just good old Vaseline will do.
  3. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    As above
    If you don't lube the O ring they sometimes pinch when pushing the pipe in and this can split or tear the O ring.
    Pull it apart again and check the O ring for damage then put some Vaseline on it and inside the hole in the tensioner before pushing the pipe and O ring back in.
