F
fattypomba
Guest
Hi all,
On a VS 1996 V6,,, Under the bonnet On the drivers side there is a little arm which operates the heater tap.
With the motor running,, When you turn the heat/cool control inside the car this little arm should open and close the heater tap????
I thought that the above would be true.
I took my car back to the place where I had the air Fixed and regased.
I claimed it was not working fully. They did tests etc for about 1 hour and said it was working as well as can be expected.
I came out on the work shop floor and talked with the mechanic. I asked about the heater tap,,as the heater tap was a problem on my VT.
He claimed the heater tap is OK. He also said it's movement does'nt come from the controls I was talking about.
When I had a closer at it look today it does NOT move when the heat/cool control is moved.
I am I correct in saying it SHOULD move??????
