heating again
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Greggles_VS, Jan 28, 2013.
  1. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    Last week I changed my water pump, this week I replaced the radiator and top and bottom hose, all of a sudden my heater is working, would there have been a pressure issue the whole time causing the issue? Or what may have fixed it? Cheers
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Should not be related to what you've done I reckon....maybe airlock or heater tap jammed.
  3. Greggles_VS
    Any chance to direct me to a how to link to fix heater if there is one? I've tried all I could find
  4. VPRob
    VPRob Active Member
    nowra, NSW
    VP executive sedan V6
    I thought you said it was working now?
    Maybe it wasn't pressurising before you replaced the radiator and hoses and that has encouraged the on/off tap to work again? Just a guess.
  5. Greggles_VS
    Lol, it WAS heating haha, thinking may need to look at the heater core, as there has to be a leak somewhere, not only is heater not working again, but idling, car is still hitting 3/4 and kicking in the fan which it never used to do, used to stay at 1/2 max
  6. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Temps when fan kick in are 'normal'....to check heater - engine idling - dial COLD - at heater tap remove vacuum hose and you should see the cranked arm on tap move - if it doesn't move tap is jammed - if no hiss when you remove vacuum hose you have lost vacuum and you will need to find out why.
    Report back.
  7. Greggles_VS
    Cheers Hako, ill prob do it tonight champ, cheers
  8. Greggles_VS
    Well I pulled the plug off the sensor, counted to 1 min and no fans turn on, replaced both fuses under the bonnet, tried again and still no fan. What do I do to diagnose the problem? I don't have a multimeter yet, but I do have a cheap shitty circuit testing screwdriver thingy lol
  9. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    You're supposed to pull the hose off the heater tap and you're pulling a plug off the sensor??? - that's to check if the fans are working. Think ya might have meant it for another thread? :)
  10. Greggles_VS
    LOL yer, I have a few threads going, ill check the heater tap in a minute lol
