Heeeelp; vn ss power windows
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by ssami83, Sep 18, 2008.
  1. ssami83
    ssami83 New Member
    VNSS
    HAS ANY ONE HAD/SOLVED THIS PROB B4? LOVE SOME TROUBLESHOOTING PLEASE ALL ELECTRICS WORKING FINE CHANGED FUSES CHANGED BUTTONS STILL NO MOVEMENT IN WINDOWS CHECKED MYFUSE BOX HAVE +POWER TO BOTH SIDE OF THE FUSE SO IM GUESSING THERE IS A FAULT IN THE CONNECTION?? LOVE SOME CONTACT COS IM A SHOCKING ELECTRICIAN AND IM NOT WANT DODGY HOOK UPS IN MY ORIGINAL:bang:
  2. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    well, could be the motors for the power windows but im guessing its probably the switches for the power windows.
    Pull them out of your console, just pull them up gently and ensure all cables are connected properly to the switch, if so check they are getting power to them. if thats all fine, might have to look into the power window motors
  3. Emackulation
    Emackulation Banned
    SE Queensland
    '92 HSV VP GTS
    I didnt know that VN SS's came with power windows?
  4. Turd Ferguson
    N.S.W
    Disco
    It was just front power windows in the SS i think
  5. stocky
    stocky New Member
    no they had the option of all 4 electric windows
  6. wildss
    wildss Member
    s.e melb
    vnss
    bridge the wiring that plugs into the switches and see if the windows move, if they do its your switches.
  7. milkandjuicecomein2litres
    milkandjuicecomein2litres New Member
    VN Berlina Wagon 5ltr
    Same issue
    I have a 89 Berlina Wagon and all the power windows work except for the driver side, does anyone know if this is common? When I press the button, a clicking sound comes from the black box thing where they are wired up, but all the other windows work and they dont click, help i need a ROADWORTHY! :wax:
  8. wildss
    wildss Member
    s.e melb
    vnss
    check a different set of switches and if that dosent work id say its your window reg
  9. stocky
    stocky New Member
    its your window motor. you can unscrew the motor from the mechanism to swap. can be a bit hard to get the new one in. i had the same problem last week. to test its your motor, you can just take off your door trim and hook 12 volts directly to the motor
  10. milkandjuicecomein2litres
    I wouldnt have a clue, but the clicking is coming from the power supply, not the door or window, so what the hell does that mean??
  11. milkandjuicecomein2litres
    Ya see, the driver window doesnt work at all the motor doesnt make a noise but when buttons are pressed the black box where the fuse is clicks but nothing, does that help or did u know all that before? lol sorry cobba but any help would be great
  12. stocky
    stocky New Member
    same thing happened to me. was fixed by changing the motor. i had the same clicking noises
  13. milkandjuicecomein2litres
    Thanks champ ill see if the motor works 2moro! :thumbsup:
  14. ssami83
    ssami83 New Member
    VNSS
    have no power in ANY windows motors are good unless they have all busted ..... changed all fuses ...have power to all fuses ...short some where between ignition and the console switches is there a fuses hidden?? damn electrics an ss convirtable would be killa :sleeping: lol betta sleep on that cheers guys
  15. taskmaster
    taskmaster New Member
    goonellabah, NSW
    2000 VT series 2
    hehe 2 of my power windows wind down a fractions the other do dont work at all and one of those that does wind down doesnt wind back up...... ideas
  16. holdenzrul
    holdenzrul New Member
    New Zealand
    Vn Calais
    My problem is the windows were working then the fuse blew and after replacing the fuse they now have no power going to the switches. Is it possible that the wiring got fried when the fuse blew? Very frustrating as i dont know where to go from here
  17. Renno
    Renno Home Of The Shiny Tank
    Defected And In The Shed
    VN Calais 5L
    Could it be the actual powerwindo module under the steering coloum if i remeber correctly?
