[WA] HELP- ABS light wont go out
vr355stroker
Kalamunda, WA
08 clubby w/Ls3, 05 VZ Lumina
G'day all,well it all started with a simple battery change. Went to SCA to get the batt,the store person was very helpful with all the right info
that I was after,so I bought what i needed,then the same person offered to install it(cool)He put the new battery in and connected with a bloody big arking,
which turned out tobe reversed.Anyway got it installed properly but now the abs light wont go out and I have no ABS brakes,
so I checked all the fuses but still no joy,I don't know what else to do,can someone help me figure this out
Ps- I noticed that the display unit has got the TracCon off sign lit aswell if it means anything
Brett_jjj
Tamworth NSW
vs commodore
You need to get the ABS codes read with a suitable diagnostic scanner.
Heres a list of VT to VY ABS/ETC error codes.
Code 12= Start up code/ system ok.
Code 21= Front right wheel speed sensor faulty signal.
Code 23= Front right wheel speed sensor short or open circuit.
Code 25= Front left wheel speed sensor faulty signal.
Code 27= Front left wheel speed sensor short or open circuit.
Code 28= Front wheel speed sensor frequency incorrect.
Code 31= Rear right wheel speed sensor faulty signal.
Code 33= Rear right wheel speed sensor short or open circuit.
Code 35= Rear left wheel speed sensor faulty signal.
Code 37= Rear left wheel speed sensor short or open circuit.
Code 41= Front right inlet valve solenoid.
Code 42= Front right outlet valve solenoid.
Code 45= Front left inlet valve solenoid.
Code 46= Front left outlet valve solenoid.
Code 47= Priming valve solenoid.
Code 48= Switching valve solenoid.
Code 51= Rear right inlet valve solenoid.
Code 52= Rear right outlet valve solenoid.
Code 55= Rear axle inlet valve solenoid/Rear left inlet valve solenoid.
Code 56= Rear Rear axle outlet valve solenoid/Rear left outlet valve solenoid.
Code 61= Pump motor or relay faulty.
Code 62= RPM signal incorrect.
Code 63= Valve solenoid relay circuit faulty.
Code 67= Stop light switch circuit faulty.
Code 71= Control module internal fault.
Code 72= Data fault.
Code 73= Requested torque circuit fault.
Code 74= Actual torque circuit fault.
Code 78= Incorrect optional coding.
Code 85= Voltage too low.
Code 58 for gen 111= Throttle relaxer PWM interface fault.
Code 62 for gen 111= RPM signal fault.
Code 64 for gen 111= Throttle relaxer control module position fault.
Code 65 for gen 111= Throttle relaxer motor fault.
Code 66 for gen 111= Throttle relaxer control fault.
vr355stroker
Kalamunda, WA
cheers m8, my wife's cousin has a work shop around the corner,why didn't think of that earlier!!Some day's I'm just thick as a brick lol
Brett_jjj
Tamworth NSW
vs commodore
No worries mate. If it were a VT or VX, you wouldnt need a scantool, you could have just flashed up the ABS codes on the ABS dashlight, just like you can flash up the ECU codes on some models. You bridge terminals 5 and 12 in the diagnostic connector to check for any logged ABS codes..
