was wondering if anyone had any ideas why the a/c pump on my VX II v6 wont activate, when i push the button the light comes on and the thermo fans kick in, but the pump doesnt activate. It started 6 months ago as an intermittent problem, just wouldnt kick in every now and again so i got the system regassed and new filters put in, and it worked fine for about 4 weeks and then went intermittent again and till the point where it wont activate at all. Would this be a dead ac pump, or could it be something small that can be easily repaired?? any help will be great thanks.
do a search could be a number of things ,did the ac place that re gassed your system put a dye in it ? if so go buy a cheap ultra violet light and check for flouro dye spray in your engine bay could be a number of things compressor tx valve condensor leaky hose leaky "O" rings evap unit welcome to the world of vt commodore air con repairs ........hopefully yours is simple .............next weekend i get to remove my complete dash to replace the evap unit (also doing heater core as well ) good luck
i did do a search and didnt come up with anything useful . acarmody how much did they charge you to get the clutch fixed, just so i have an idea what price range i will be up for
