help asap anyone
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by leigh 7005, Feb 5, 2009.
  1. leigh 7005
    leigh 7005 New Member
    adelaide
    vb sle
    im changing rear main on vn s1 v6 now on the rear main bearing cap you have to like key ways dose anyone know where i can get the rubber keys for it when i pulled it apart it was filled with silicon so it wasnt even rear main leaking darn vn:bang:
  2. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    ummmm, what? you might have to rephrase that cause i cant understand what you are talking about.
  3. leigh 7005
    adelaide
    vb sle
    it gose between the block and rear main bearing cap
  4. Tom_1569
    Tom_1569 Ecotech Power
    Gippsland - VIC
    '14 SR5 Pusslux
    I'm changing the rear main seal, on a VN Series one V6 engine. Now on the rear main bearing cap you have two key ways, does anyone know where I can get the rubber keys for it. When I pulled it apart it was filled with silicon, so it wasnt even the rear main seal leaking. Damn VN :bang:
    It goes between the block and rear main bearing cap.
    Hope that helps people understand what your trying to say, Im not trying to offend you, but it was very hard to read.
  5. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    You dont need keys, just use some high temp silicon to seal it back up, the VN S1 is a rope seal so are you sure its ok? they are pricks of things i did blew my seal and could'nt find it anywhere.
  6. leigh 7005
    adelaide
    vb sle
    fixed today ad ther is a rubber seal and it cost $84.00 from holdens its a genuine holden part and sillicon is not going to hold oil under pressure
  7. leigh 7005
    adelaide
    vb sle
    also i converted it to two piece neropane seal
  8. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    Sorry you have lost me.... S1 Rear main seal is a 2 piece seal, either being rubber or rope seal. and i used high temp sealant around the bearing cap and it hasnt leaked a drop, i also just put a rope seal back in, $84 is alot of money just for some rubber lol.
  9. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    Yeah there's meant to be 2 rubber blocks (uhave to use silicone aswell anyway) that in theres but silicone works just aswell theres no real pressure on it unlike the rear and the sump sits over the top so it wont go anywhere. Yes you can either get rope or neoprene and $84 is a rip off i would have got and acl or other brand like permaseal one for less than half of that.
    Also your supposed to use a flange sealer on the bottom of main cap i hope you put it there or oil will weep out
