HELP ASAP with pedal box!!
georgeonboost
clutch it!
Melb SE Suburbs
slammed VP EXEC
guys, i need help with my manual conversion, in particular the pedal box. its all in no worries but the pin at the top that the booster rod goes onto doesnt have a hole in it for the pin like the auto pedal box did. what can i put there so it doesn't move and slide off? there is like an indentation part at the end. is there like a clip thats meant to go there?
by the way im refering to this pin hole
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
it should have c shaped clip on there
maldotcom2
Cammed mafless VS Calais 5-speed.
If there's a groove all the way around it takes a clip, if there's just a hole straight through just use a split pin like i did. Varies depending on model.
Morton
For external use only
33
Fairstar the Funship
Wow, I've not seen a booster knuckle that used a cotter pin before. How unusual! :D
