HELP caliper->hub bolts ridiculously tight
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by pow3rslave, Mar 25, 2009.
  1. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    all 4 wheels need new banjo bolts, so while i'm doing brake works i thought i'd take the front calipers off to respray them.
    i've only taken the rear ones off before. but when i got new front discs and pads they must have done them up with a rattle gun or something cause they're stupidly tight. for a second i thought it might be reverse thread, but i didn't remember the rears being reverse threaded
    tried a bar on the end of my socket wrench, hitting the spanner with a hammer, nothings shifting it.
  2. leigh 7005
    leigh 7005 New Member
    adelaide
    vb sle
    got any penatrine or wd40 give that ago then try they are some tight suckers
    pow3rslave likes this.
  3. ScoHar
    ScoHar Jizz in my pants
    CHCH, NZ
    VS Senator
    take that whole caliper mounting piece off and put it in a vice give that a go.
  4. pow3rslave
    eastern subs, vic
    VP 5.0L
    tried wd40, still wouldn't budge
    you mean like disconnect the tie rods etc? if i had a vice i'd maybe give it a shot but unfortunately not.
    might take it back to the place that put on the discs and pads and tell them they rattle gunned it too tight.
    i know it's a safety thing but i didn't think the torque necessary on them was more than a person could do manually
  5. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    I've never had them that tight that they won't undo with a bit of help. The ratchet or breaker bar you are using isn't against anything is it?
    Let it hang down and use your foot to put pressure on it.
  6. centy
    centy Member
    Vp series 2
    you mean the 3/4 dolts on the back of the caliper bracket?
    Those suckers are suposed to be tight, long bar and foot is the choice.
    Don't worry they are grade 10 and super strong.
    Why do you need 4 banjo bolts? What have you done to stuff all four of them?
  7. pow3rslave
    eastern subs, vic
    VP 5.0L
    when put in new rears i noticed one was warped by being too overtightened. the hole through the side was less and O than it was an O, then when i put the bolts in, one snapped. i had another on hand so i was lucky. but i got a new set and been mening to do em for a while. figured while it's being done i can paint em properly too. right now i've got shiny red rears and crappy navy fronts with rusted hubs.
  8. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    they actually have a very low torque rating, rattle gun is just stupid if true.
    All i can suggest is put a breaker bar on and "rattle" the **** out of it to get it off.
    There has been no bolt on the car that i haven't been able to get off with blunt force and breaker bars.
    Try to snap the thread lock, ie, immitate a rattle gun with a lot of force in short bursts.
    aZk.
  9. Tom_1569
    Tom_1569 Ecotech Power
    Gippsland - VIC
    '14 SR5 Pusslux
    Agreed, heres the VT specs from the manual:
    Front brake caliper anchor bolt 80 - 90 Nm, plus
    40° - 50O turn angle
    Rear brake caliper anchor plate bolt 70 - 100
    In perspective a wheelnut should be 110-140nm.
    I just use a small breaker ball and my foot. If its really tight get a large breaker bar and a bigger foot lol.
  10. azkwazere
    .....SE Burbs
    A bash mallet or panel beaters dolly on a breaker bar should be sufficient.
    aZk.
  11. pow3rslave
    eastern subs, vic
    VP 5.0L
    goddamn, just got it off, i had to buy a 380mm breaker bar (the tube wrench on the end of the socket didn't do it) then put the tube wrench on the end of that, even with that it was hard going.
  12. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Want to buy a weight set?
  13. pow3rslave
    eastern subs, vic
    VP 5.0L
    already got one thanks. as i said before i think they used a rattle gun to do them up
  14. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Sometimes people do bolts up to that last setting on the torque wrench....."ridiculously ****ing tight"
  15. ScoHar
    CHCH, NZ
    VS Senator
    yea most bolts are done up F.T
