HELP Central locking issues VP
stu29x
Columbia
VP Exec 3.8L
I am tryin to fix my failing passenger's rear lock.
I have tried 3 different actuators
The wiring is ok as the lock will not come back up.
Sprayed WD-40 in there to loosen up the joints but it still seems like there is something holding it back.
Can anyone tell me how they fixed their issues, thanx.
Full Spectrum
Bro it's a VW your Audi!
www.news.com.au
Berlina V6
So it locks but it wont open?.
You could try taking the motor out and seeing if it works both ways. It might be a bent arm to the motor? Or even the button on the door itself might be ****?.
WD40 worked for me:)
stu29x
Columbia
VP Exec 3.8L
Locks
yea it will lock most of the time but to do that i have to manually pull it up (unlock)
Full Spectrum
www.news.com.au
Berlina V6
Is it hard to lift the button at all? Maybe something isn't right in the motor if it only goes one way?. Or even the arms that go to it might be bent or button might be stuffed?
stu29x
Columbia
VP Exec 3.8L
I think i may have worked it out , b4 i owned the car a m8 had a prang in it and it was on that side , a new door skin and rear bar later it looks new, but i am thinkin it bend the rods or the mechanism.
H
HATER VP
Guest
Possibly, But if that was the case it probley wouldnt lock or unlock. Not just lock like urs is doing. Are you sure you havent just got a heap of dodgy actuators
commy92
VP WAGON V6
my drivers door does this sometimes. i should prob rip the door card off and have a look. But i need to sound deaden my doors so ill wait till i can afford sound deadening.
stu29x
Columbia
VP Exec 3.8L
Problem Solved
After way too much screwing about , i replaced both actuator and mechanism from the wreckers he ripped me but i just wanted the prick fixed.
