Help: dash light
cyuon
SYD
VS Executive 3.8l
Hi guys, my holden commodre VS has a problem on my dash. The battery light keeps coming on when i brake or step off the gas and when i accelerate up to 3,000 rpm the light goes away.
Does anyone know the problem ? As I've already changed the battery and the light is still showing.
cheers guys~ :)
ben315vz
Donating Member
Tamborine Mountain, QLD
'05 Holden VZ Calais V8
It could be the alternator not charging properly. May need to recondition/replace your alternator.
RX25SE
Real cars are steel cars.
MY07 Liberty 30R Spec B 6sp wagon
+1 for alternator fault.
sneezy1
vr berlina
I'd check the regulator....on the back of the alternator.
ShawtyNate
In the feels.
i got a prolem when i start, that orange engine light stays on for about 2 secconds but then goes off. does anyone know whats wrong with that
yoshi87
south australia
vs commodore
the best way to check the altonator is to get a multi meter and start the car and see if the battery is charging at low revs then rev it up a lil if the numbers dont go up then the regulator is faulty, but then again could be a problem with the running gear in the altonator, if that all is fine the there is a further fault
