Help, DOes any one know - easy
COMMY VP 666
COMMY VP V6
COMMODORE VP
does anyone know where the
oil pressure regulator is on a vp 5litre
let me know thanks
centy
Vp series 2
i would expect it to be in behind the oil filter.
COMMY VP 666
COMMY VP V6
COMMODORE VP
by any chance is it part of the oil pump assembly
like when you change the oil pump over, it also changes over the "oil pressure regulator"
spirto
VQ Caprice II
Morton
For external use only
33
Fairstar the Funship
Yup, should be screwed right in on the oil pump, and you'll find it just behind the oil filter. If you can find the oil filter, you'll find the pressure reg no problems.
COMMY VP 666
COMMY VP V6
COMMODORE VP
hey thanks been heaps of helps
how many wires are going to the oil pressure regulator
and what are they coming from
does anyone have a wiring diagram for the oil pressure regulator
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
pressure regulator doesnt have wires but the oil pressure sender for the oil light does
