HELP! Draining fuel
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Chirpstr, Dec 12, 2007.
  1. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    I'm in the middle of draining my fuel from the tank and need some help on it.
    This is what Ive done so far,
    Disconnected fuel filter,
    Put some hose from the outlet of fuel pump straight into a drum.
    Cranking the engine doesn't make it flow bugger all?
    What should I do?
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Run a wire from the feed on the fuel relay directly to the positive terminal on the battery.
  3. Chirpstr
    ahhh cheers matey. Life saver!
  4. Chirpstr
    2 orange, puple, green and a black. What one?
    Tried using the multimeter but cant be quick enough within the 2 second of it being on...lol
  5. Chirpstr
    Purple one right? could be wrong. Only one way to find out. Well im pretty sure its the one for the pump. And because its a bigger one.
  6. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Look at the colour of the wire that goes to the pump, it should be the same as the one at the relay. Won't hurt by trying them all, just don't do the black one.
  7. Chirpstr
    Job done! Ha yeah only do the Earth if ya want fire works lol.
    Cheers Again Mate.
  8. Silver surfer
    Silver surfer Banned
    04 VY Executive
    u could of just undone the drain plug on the tank
  9. vsiicalais
    vsiicalais Donating Member
    Wonthaggi
    MY15 VF SV6 Storm
    some dont have drain plugs so all i normally do is loosen the bolts for the pump and let it drain that way.
  10. Chirpstr
    No Drain plug for the VR, VS. Well I defenitly know the VR's don't have one and can't see why the VS's would have one either. The strainer would be the lowest point for it to drain the most fuel. Sure, you could drain fuel by removing the bolts for pump but way more convenient and no fuel will be left in the tank if you do it the way Not_An_Abba_Fan Suggested.
    Cheers Again Mate Worked A Treat!
  11. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    No worries. Bill is in the mail....
  12. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    You can block off the hoses to the charcoal canister and then apply air pressure to the fuel filler - minimal air pressure only and not enough to distort the tank. Fuel can will then flow out of the inlet and return hoses. Have seen this done when the pump is dead but dunno if I'd recommend it. Watch out for sparks!
  13. Chirpstr
    Bill in mail? Really? How much?
    haha JJ
    And cheers Hako, Good idea if pumps shot.
