anf355
- Nov 6, 2018
- 29
- 2
- 3
- Location
- victoria
- VB Commodore
Hi,
I'm upgrading my old points distributor to electronic on my VB 253, the two options are bridging the starter and ignition wire to give my coil 12V rather than the original 9V, Do I understand that correct.
I've also read a 12V power source can be run direct to the relay and the original ignition switch can be used as a switch. Relay as follow - 12v = 30 , 87 = ignition (original) , 85= coil and 86=earth (body).
Is this correct?
Is it acceptable run the 12V fromct form the battery post or on the starter or alternator wire?
Cheers Anthony
Is this correct?
Cheers Anthony
