help fitted a swoosh tacho no lights
rob drag racer
vn vp drag nut
golden beach
forums.justcommodores.com.au
vp 3.8 with gas new project vn s1 guted strip only
i fitted my swoosh tacho today and cant figure out how to set up the lights for night view there's a cord from it with 4 gray wires and a yellow i understand where and how i would fit it to the lights on switch but cant figure out how to with these wires has anyone came across this before and if so i would love the help
other than that it works fine just cant see it at night !!
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
It must have come with a manual to give you a clue. I would imagine 1 wire is earth and another will run to the globe. Can you pull the globe out at the back and continuity test the wires to work it out, that would be the easiest.
SMIT
Donating Member
Mornington Peninsula, Victoria
VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
I just went and had a look at a swoosh tacho i had lying around mine has 5 wires coming from it:
These 3 wires are connected to the rear PCB board:
red = 12v
blk = groun
green - tacho pulse
These 2 which i assume are the illumination and seem to be connected to the outer edge of the tacho
red = illumination wire (tap into ciggi light power)
blk = ground
