[HELP How 2 replace rear wheel bearings IRS
VZ57SSZ
Central Coast
MY16 VF Series II SSV
Hi
I need help on how 2 replace the bearings in my VR the car has IRS/ABS, I have the bearing kit however need help installing them as I need 2 replace them urgently and can't afford to have them installed professionally at current.
Thank you for any help
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Checked my books and they all say take it to a workshop as specialised equipment is required to disassemble the hub.....so I guess that means you need a decent press etc. Sorry I cannot help more.
Harvs82
41
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
Yep, unfortunately you need the proper press etc to get the old bearings out and stick the new ones in.
The old ones will be absolutely buggered... mine had to be almost smashed out, and when they did come out, the actual ball bearings fell out everywhere... right over the entire workshop floor.
There is quite a bit of labour involved too, as both the rear driveshafts need to come out and then the bearing itself, and then the whole lot has to be put back together.
VZ57SSZ
Central Coast
Thanks for your help guys, seems i have no choice then but 2 have them done. Just wondering how much did it set you back when you had yours done?
Thanks
Harvs82
41
Glen Waverley VIC
Thanks
From memory it was about $200 in labour to get one of my rear bearings replaced... but that was a few years ago now. The actual bearing itself only cost around $60.
