Help Identifying These Plugs :)
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by 1991_Vn2nV, Jan 8, 2008.
  1. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    In the middle of putting a new loom in the VN, but I cant find matching plugs for the following... So any help with what they are would be awesome :)
    These SHOULD plug somewhere near the glovebox area as the plugs are located in the same spot as the wires for the glovebox light and remote boot release:
    http://img175.imageshack.us/img175/1015/mysteryplugsonvqloom1tv2.jpg - Anti Theft Module
    This one however was already in the car lol It is above the ECU, not sure where it should go??
  2. 1991_Vn2nV
  3. georgeonboost
    georgeonboost clutch it!
    Melb SE Suburbs
    slammed VP EXEC
    the glovebox...thats a refrigerated unit...i think it runs off the aircon??? not sure tho...u can keep things cold in there. a mate had one in his vr stato.
    -George
  4. 1991_Vn2nV
    lol I wonder who came up with the idea to turn a glovebox into a fridge?
  5. NickVR
    NickVR Active Member
    Adelaide, SA
    VR Executive A4 V8
    Those green and white plugs look like they are for the BCM/Anit-theft module. That usually hides under the dash above the glovebox. Not sure about that 3 pin plug though
  6. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    3 pin plug is a economy/power switch connector or at least a vr/s uses one of these for it.
  7. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    Toyota Tarago had one so.....
  8. 88GreenVN
    Surprise, Arizona
    As above ^^^^^ the anti theft module.
  9. 1991_Vn2nV
    Ah excellent. Not sure what to do with the 3 pin plug now though? Its out of a 91 VN Calais so not sure the economy/power switch connector :S
    Thanks heaps for the help guys :D
  10. 1991_Vn2nV
    Thought i'd chuck up another few.
    Light for immobiliser or something perhaps... Comes to centre console area... No not gearstick light:
    Connects to this about 10cm down: http://img219.imageshack.us/img219/7274/unknownlight2jy6.jpg
    Now as for these im thinking brake switches for Cruise Control? Comes out to under the steering wheel:
    And lastly this... Single green wire.. Runs off past the cluster connectors:
  11. NickVR
    Adelaide, SA
    VR Executive A4 V8
    Security light in first pic, is right. The 2nd pic I would go with you on that one but that last one I'm not sure.
