Help!!!! leaking coolant at the back of the motor?
Tomika
queensland
08 ve holden omega
hey, i have a 08 ve holden omega, my cars been using minimal coolant couldnt find any leaks tho, but i recently took it on 800km trip and noticed leaking from the back of the motor but cant actually tell where its coming from, it not over heating or anything drives fine! just using coolant when it shouldnt be !
HEELLLLPPPPPPP!!!!
ChRiDDa
N/A
VE SS-Z Sportwagon
Look at the 2 heater hoses at the rear of the engine on the drivers side
Failing that, could be that your thermostat housing is leaking
stick3
newcastle nsw
vz sedan vs ute gsx1400
common problem with the alloytecs thermostat housing leaking it just in a bad location this is youtube vid of a vz
gohrdrgomad
Australia
VxCaly57
HEELLLLPPPPPPP!!!!
looks like you need to help yourself....
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
This is what you dealing with. Good luck.
You got 3 different way to tackle this.
1...Have to pull top half of the engine out (inlet manifold, injector rail etc. etc.)
2...Have to separate the tranny from the engine,
3...Take car to your trusted pro.
Tomika
queensland
08 ve holden omega
thanks for ur replies guys ive tried to post actual photos of where the coolant coming from the back at the top of the motor but it wont let me !!
Tomika
queensland
08 ve holden omega
Tomika
queensland
08 ve holden omega
Hi guys!!!!!
my mechanic replaced the thermostat n housing and im sure it still leaking when i take my radiator cap of there is lose of coolant but not much?
any ideas ??
Bonus
40
Christchurch, New Zealand
2008 VE SV6
Keep topping it up, as the system may still have small pokets of air that are bleeding out
