help me make my commi handle betta
Discussion in 'General' started by VPS2, Oct 17, 2008.
  1. VPS2
    VPS2 New Member
    VP Executive S2
    hey can u guys tell me whats the best thing to buy to make my vp handle better besides coilovers
  2. hakhawk
    lower springs, stiffer shocks, bigger sway bars, urethane or at least new rubber bushes, etc.
  3. nicko
    sa
    75 cruiser ute
    yep: new bushes, bigger sway bars, short shocks. will help
  4. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    why not coil overs? I want coil overs.
  5. hakhawk
    probably because prebought stuff is too dear for some people.
    but with access to a welder and grinder, i was able to make a set with adjustable shocks for under $1000(minus labour and strut tops)
    coilover sleeves and spring tops = $160 from uk
    350lb 8" springs = $150 from uk
    koni adjsutable front strut inserts = $600(i think retails around that) from toperformance
    swap out the adjustables and you'll save a few dollars. welding wasnt much involved, just welding the threaded sleeve to the strut housing, and i got shorter strut inserts, so theres a weld join hidden under the sleeve.
  6. STEALTHY™
    STEALTHY™ So Wet For You!
    SA - The Roadworks State
    Take one VP Calais International, add springs/shocks, strut brace.
    Job done ;)
  7. jules
    jules we like the bun
    pimpin
    body kit with whale tail rear spoiler?
  8. hakhawk
    he said better :p
  9. immortality
    Sth Auck, NZ
    damn, you make those? nice :thumbsup:
    i know you can buy a kit somewhere in aus to convert standard struts to coil over much like in the pic above. not cheap though. can't beat a coil over setup for handling
  10. wildss
    wildss Member
    s.e melb
    vnss
    sorry to hijack but why do coilovers handle better than a standard setup?
    obviously its the design but what part of it makes it superior?
