Help me to trick my ECU..
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Zipster, Feb 10, 2009.
  1. Zipster
    Zipster New Member
    Braidwood
    VS-1995 Hydrogen Fuel Saver
    Hi there,
    I'm looking for someone that knows well about ALDL ECU. I have this device that is hooked in between the computer and the O2 sensor.
    Dual EFIE Deluxe - $114.95 : FuelSaver-MPG Store
    And I'm looking for the best setting, an amount of milivolts that the computer can accept without the engine to fail in order to lean my fuel mixture the most I can.
    Anyone knows if I add 200mV on the sensor line what fuel/air ratio it will be?
  2. holden_man86
    holden_man86 Banned
    vs executive commodoer
    13/1 well that what i can work out mate
  3. stocky
    stocky New Member
    you just bought an ebay resistor mod chip
  4. Zipster
    Zipster New Member
    Braidwood
    How did you work this out?
  5. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    So you want to lean out the mixture to save on fuel? Won't work, sorry. the ECU is a pretty smart piece of gear and will soon compensate for any adjustment you make.
    All that will probably happen is that your engine light will come on and you will get an error code. Worse case scenario you will melt your cat, lean = hot.
    Also the ECU leans out the mixture on the highway anyway.
  6. Zipster
    Zipster New Member
    Braidwood
    ?????wtf????
  7. Zipster
    Zipster New Member
    Braidwood
    That's not "it". I need to fool the ECU because I'm adding some HHO gas (Hydrogen) through the air intake so it can accept this gas as a fuel and not simply react as if it was oxygen. It works mate. Look it up.
  8. danja
    danja Swerves for gay koalas
    CBF 250 and a Levin ZR
    Oh dear... I sense a Brown's Gas theory coming on...
    Firstly, you shouldn't need to trick the ECU, as the O2 sensor is in the exhaust stream; so if you're adding combustible material before the exhaust, then the mixture will run rich and the ECU will lean the mixture to stoichiometric levels anyway.
    Secondly can you explain how your hydrogen generator (electrolysis I presume?) consumes less energy splitting H2O molecules than is provided by combining them again?..
  9. dufus
    dufus Donating Member
    rickshaw
    LOL the ole Hydrogen Gas Injection, let us know how it goes mate :yeah:
  10. Zipster
    Zipster New Member
    Braidwood
    Its going really good. I'm saving between 25 and 40%. Hydro is doing great for me, try it. At the moment trying to bend the ECU even more to reach max savings possible. I heard lots of people dissing this technology, all I say is that they should try before they judge it.
    I'm still waiting the answer from man86 to figure out the ratio change in terms of milivolts cheers.
  11. Zipster
    Zipster New Member
    Braidwood
    For the skepticals, have a read through this Post Your Results
    You can find a first price setup around 200bucks all up.
  12. danja
    You realise you'll get those gains by leaning out your AFR anyway, hydro or not? the downside will be when your engine breaks down from all the pinging and overheating, not to mention all the extra toxic emissions you're all pumping out now.
    There is hard science which explains why the hydro setup is unnecessary. I don't fancy turning over $200+ to confirm that.
    For the delusionals, have a read through this: Scientific proof proving that HHO scams are a fraud
  13. Eliminator
    Eliminator New Member
    Maranello red Vn V8 Calais
    why would you buy a vs if your concerned about fuel economy?? theres economic 4 cylinder rice burners you can afford that will keep up with your commodore
  14. Zipster
    Zipster New Member
    Braidwood
    Danja, you have your opinion, my goal is not to change it. In reality you can find 2 great families of people, the conservatists and the progressivists, and they never agree. Think the way you feel is good.
    Eliminator, you are right 100%. However I think a v6 is more interesting in terms of driving. As we speak, my vs does not drink more than a 4cyl anyway, with even more power from the HHO.
    Gentlemen, I'm not interested in any political debate and I'm not trying to sell my stuff, was just looking for a technical info, and I partially got it so cheers up!
  15. danja
    Sure, we can agree to disagree.
    Moving beyond the issue of does hydro work, you ought to be aware that by tricking you ECU into leaning the fuel mixture you are going to:
    1) Increase combustion temperatures, which has implications for the long-term life and reliability of your engine.
    2) Dramatically increase NOx emissions (the really bad ones) which would cause you to fail an emissions test should you ever be required to have one.
  16. VN_Luke
    VN_Luke ƃuoɹʍ ʇsnɾ sı sıɥʇ
    Mexico
    Get in the ute
    Oh, in that case - get a hold of a member called "Greenfoam" on these forums, or he's (better way to contact him) also available on eBay under the user 'nicefrog'
    you can them tell him how much % less fuel you want, at what RPMS and at what engine loads, and he can alter the values in the ECU memory to inject less fuel when you specify.
  17. Zipster
    Zipster New Member
    Braidwood
    Well danja, how do you explain that dyno tests shows that my carbon emissions has reduced in half..
    Lets have a proper discussion about this, I'm down with that. I made a thread for it, let's go.
  18. Jesterarts
    2010 Nissan X-Trail ST-L
    Sweet... thats very impressive...
    So you have the before and after dyno charts... with results like that I'm sure alot of people would be very interested in this gadget.
  19. danja
    Because NOx are not carbon emissions. Carbon emissions are CO2 and unburned hydrocarbons (and some intermediate products).
    Let's continue this in your new thread in the pub.
