help me with probs on superlow and jacking up?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by timmy_tam, Mar 26, 2007.
  1. timmy_tam
    timmy_tam New Member
    VN calais 91
    i just put in superlows all round, and now i have the problem where if i jack it up, the wheel doesn't rise up until you jack it up really high
    i guess i need shortened shocks, but i heard you only need shortened shocks for ultra lows, not super
    also, the springs fall out when i jack it up, which could be an issue in an emergency
    any ideas aside from new shocks?
    [​IMG][​IMG][​IMG]
    also, what is this part? its connected to nohting
    and are these bushes fuked?
    THANKS!
  2. mattman
    mattman New Member
    '00 WH V6
    Bushes screwed, and get short shocks.
  3. hakhawk
    just get the monroe shocks for cars with fe2 suspension. i have them in mine, with ultras and the springs dont fall out
    the part that "connects to nothing" is your bump stops, you need them, so the axle doesnt bash the chassis.
    yep, those bushes are stuffed, theyre mainly there to keep the spring from moving around and scraping the chassis making rotten noises and wearing the metal away.
  4. timmy_tam
    VN calais 91
    thanks for the quick replies
    will check out some new bushes, as i have been hearing clunks and thunks while turning and coming to stops
    probabbly the bushes
    will check out new shocks, but i was led to believe only ultra lows needed shortned shocks
    wrong info?
  5. hakhawk
    definately wrong info. lows you can get away without short shocks, but superlows and lower, generally need shorter shocks.
    the fact that you yourself can see the springs fall out when its jacked up tells you that you need short shocks.
  6. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    King Springs reccomend shortened shocks be fitted with even Low Springs, let alone superlows and lower.
  7. padrickz88
    padrickz88 Rick =]
    sunshine, melbourne
    VN V6, nothing special
    how much would them bushes cost? i think the ones on my rear end need replacing.....:)
