help me!!! :(
smitroast
wynnum
vz sv6 commodore
when I first bought my double there wasnt enough room behind it to push It all the way back so I cut the whole stock head unit lume out as stupid as I am I threw it away now I have come to a few computer problems with doing this I want to know can I wire all these wires together so it will do the exact same thing or will I have to take my car to an autolecci :(
smitroast
wynnum
vz sv6 commodore
And honestly if you have nothing general about this to say dont say anything because I rwalise how stupid I am and thank you
smitroast
wynnum
vz sv6 commodore
First off abs then I started it again it the after noo and low fuel xame up service need came up then the computer screen is just stuck on "servis error contact dealer" the fuel gauge doesnt work or the temprature gauge and traction is always off
jayzz_23
With the loom that you threw away way their any plugs with it or is the plug still connected to the unit
holdenvtman1123
Improvise Adapt Overcome
Broken Hill NSW
www.google.com.au
VZ Adventra LX6 2006 3.6L
how far back did u cut the loom?
richardpalinkas
Blown Alloytec
Gold Coast
Raptor Impulse VZ SV6
Did the problems start as soon as you cut the loom?
patrick niesler
sunny coast
VY SS
the VY/VZ had 2 constant power wires going into the back of the unit. I have heard that if you tap into the wrong one that it stops the alternator from charging. could possibly be the issue, trying to find the diagram. I cant remember which of the 2 constants you have to use
- had no luck searching. Might be worth checking the wires for the other constant power and connect to it to see if the problem persists.
FstStig
Diagnostician
Central Coast, NSW
2010 VE SV6
English lesson might help you which in return will help us, to help you.... See what I did there?
