HELP- motor cranking but not starting
Discussion in 'General' started by Dr HaxZaw, May 14, 2011.
  1. Dr HaxZaw
    Dr HaxZaw New Member
    R34 GT-T
    I just went to start my car (VY ecotec) and it fired once and then died so i figured i must have not kept the key turned for quite long enough
    now it will crank but wont start and after a few seconds of cranking comes up with the check engine symbol... the dash says the battery has 12.2v and im at a loss as to what it could be cause the car was running fine this morning
    im guessing it could be the immobiliser but how can i be sure
    HELP!!!
    (if need be ill get nrma over here but i was hoping to get it sorted myself as i have all this afternoon and tonight to get it sorted)
  2. Burnout124
    Burnout124 Member
    Western Australia
    VY Executive S2/ VY SS 6sp
    disconect the battrie for ten sec then try
  3. Dr HaxZaw
    R34 GT-T
    yeah tried disconnecting the battery didnt do it...
    found out its the plug that connects into the bottom of the coil pack so it starts now just hopefully keeps working that way
