found the problem
speaking to alot of mechanics around au and they reckon its the tps sensor it seems to last as long as the oxygen sensor does which is not long they also said its the main cause losing power under acceleration you have to remember it tells the ecu how far the butterfly opens so if the tps is stuffed the butter fly would be wide open under full acceleration but the ecu thinks its not so see you have no power:w00t:
