help need !!! vz
candy74
dalby
vz executive v6
hoping someone can help!!! i brought a vz about 2 mths ago and i have had a error code come up about 8 times since then. It has been towed once and they told me it was a gasket in the air box, but a week later it did the same thing. Since then it has been in 4 different holden dealers and no one seems to know what it is.. the last codes were (p 2188 and p2190 ) any ideas.the error thing tells me check powertrain, but only seems to happen on a long trip , is fine around town.... but is hard to start everytime i fill up ???????
300kplusvz
Byron Bay
VZ alloytec commodore
I've got the exact same problem with mine, even down to the hard to start when I fill up.
Sounds like maybe fuel pump or the solenoid up front.....I'll let you know how I go.
Oh and by the way, how are the 02 sensors? I replaced all four of mine thinking it was them but no luck, that insistant beep still comes up every time after I reset it.
:axe:
Ahmed Wulf
Saudi Arabia
Lumina\\Commodore VZ V6 2006
After all this talk none of you put the solution...?
but 88Green, your link is very helpful.
Speddie23
37
VZ Calais
Resurecting this thread as I had this with my V6 VZ. It would randomly throw the "check drivetrain" thing.
When i ran an OBD2 scan tool, it would be either just a P2190 error or both a P2188 and P2190 error.
I would clear it, and it would be fine for a few days, then a few days later, it would return.
Taking a good look in the engine bay, I found the PCV tube was perished and cracked where it meets the throttle body (that about 12mm hose on the drivers side of the throttle body). Looks like a minor vaccum leak.
Fixed that, and it seems to have fixed the issue, as it's been about 2 weeks without it throwing an error (touches wood)
Pictured is a picture of an alloytec engine bay in a VE I got from Wikipedia, circled is where the hose was perished.
