Help Needed For Vz Execuitve 05 Model
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by nvspaz, Oct 30, 2007.
  1. nvspaz
    nvspaz New Member
    Vz executive 05
    Hi guys im new to these forums seeing how i just bought my first commodore its a white vz executive 05 model i have a few questions that im hopign use can help me out with.
    What fog lights do i put in and where can i buy them and install them?
    How do i get affordable power kW thats not expensive
    what kind of rims would suit a white vz executive 05 model
  2. darthvader
    darthvader New Member
    2006 vz executive
    Not that I know much but...
    Hey mate, in the same boat, tho i know a little from a more learned friend. Apparenly the diff ratio is kinda ordinary so changing that is a +. Cold air induction is an easy 11kw and getting the chip tuned to 98 octane fuel is around another 10 or so from what i have read. There are the standard ones like aftermarket air filter and exhaust system too. BTW just for fun u can hold in the mode and set buttons while starting the car to view the service menu if you are enquisitive like me.
  3. commodore2004
    commodore2004 New Member
    vz berlina
  4. Troy711
    Canberra, ACT
    2011 Mitsubishi Pajero GLS
    as for rims... i would go for a set of 18 inch 5 spokes in shadow chrome. chrome looks tacky on white and silver finish looks cheap.
    or, these in black:
  5. Torquative
    Torquative Sports Economy
    VE SV6 3.6L SIDI 6sp
    fog lights tho either need a SS/SV6/Calais/Berline/SVZ etc bumper bar ... ie a model that has fog lights, if you want it to blend in and look stock.
    Otherwise any fog lights will do if you just want to bolt them onto the current bar.
    The wiring is there, it goes to a plug because when you buy the genuine fog lights they just plug in. If you get aftermarket lights tho you'll need to cut the plug off and hardwire them iun.
    You also need a relay for the fuse box and the fog light headlight switch that pulls out for foglights.
  6. Troy711
    Canberra, ACT
    wiring is not there, or atleast it isnt in my ute
  7. f1tzy
    f1tzy New Member
    Brissy
    FG XR6T Ute manual
    nor in mine
