[Help Needed] Holden VN Berlina Wagon (Want to buy keyless entry!)
Excale
Aussie N Proud!
Melbourne, Aus
VL Berlina 5sp Manual[SOLD], VN V6[SOLD],VR S 5sp
Hello,
was wondering, how does the keyless entry work? it says 4 door on the box but my VN wagon is 5 (including boot!)
Help is much appreciated,
Cheers Brad
COMMY VP 666
COMMY VP V6
COMMODORE VP
generally, you dont include the boot, but they are able to be wired up so you can pop the boot , same button different button up to you.
for vn the module is called bcm (body control module)
does that help ya out
Excale
Aussie N Proud!
Melbourne, Aus
My father owned a 1996 Subaru Wagon which had keyless entry which locked 4 doors plus the boot.... I dont understand
STEALTHY™
So Wet For You!
SA - The Roadworks State
My VP has factory remotes that activate the boot, however, its not on a separate button (even tho there is a boot button). It just unlocks and locks when you hit the doors button. Maybe look at getting a setup out of a stock wagon? (Berlina etc)
hakhawk
smooth moderator
Staff member
35
Hello,
Cheers Brad
with aftermarket keyless entry, you would need to buy a 5th actuator and wire it into one of the rear doors.
Excale
Aussie N Proud!
Melbourne, Aus
Thanks for your help.
Thanks for your help. Will look into it.
