Help needed.. Vy commodore not starting
Discussion in 'VY Holden Commodore (2002 - 2004)' started by REED1E, Sep 17, 2015.
  1. REED1E
    REED1E New Member
    Vy s2 executive wagon
    Long story short, my vy broke down, it has fuel pressure, has ignition on the dash, turns over but has no spark at all, has anyone got an idea of what to try?
    Cheers guys
  2. Maxpower
    Maxpower New Member
    Central coast
    2003 vyS
    Coil pack maybe
    Coil pack possible
  3. Bowen
    Bowen New Member
    Alstonville
    2002 VX S manual 3.8L SP
    Take a lead off coil towers and try and start does it spark?
    Scan for error codes
    What do you mean it broke down? We need some more information.....
  4. REED1E
    REED1E New Member
    I've looked at plug 1 and 3, no spark in eather, which is 2 coils,
    I was just driving to work 1 morning and it just stopped, no hesitation, no spitting, not running rough, just stopped, it turns over but it does not sound like it wants to start
  5. edals
    edals Well-Known Member
    Here
    VE Equipe
    Check all fuses and relays. Check to see if you have injector pulse, use a spare Parker light, bend out the pins and stick it in a connector of a injector and see if it flashes. If so we know the crank angle sensor is good and I'd be thinking the DFI module.
  6. REED1E
    REED1E New Member
    All fuses and relays have been checked, I'll try the Parker light when I get home, is the dfi module its own component or is it also called the ignition module?
  7. Maxpower
    Maxpower New Member
    Central coast
    2003 vyS
    Aaaaah true on the cas, I didn't realise it would kill all spark.
  8. edals
    Here
    VE Equipe
    Yes it's the part under the 3 ignition coils. Easy to replace.
    If you have a dead cas it won't know when spark etc
  9. caaf
    caaf Member
    Melb, Vic
    VYII Equipe S/wagon V6
    Agree with the crank angle sensor.. In the old VN days I had an issue that a bottle of water on the CAS sorted.
  10. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
  11. REED1E
    REED1E New Member
    Couldn't check codes, I don't have a scan tool, thanks for all the help guys, turned out to be the ignition module :)
  12. cam84
    cam84 New Member
    Bayswater Victoria
    2002 VX Acclaim Series 2
    I had the same issue with mine turned out to be the fuel pump relay , mechanic also told me at the time could be a crank angle sensor issue . The DFI module can also cause this as the is a power pin that goes directly to the crank angle sensor hope that helps.
  13. Jxfwsf
    Aus
    commodore
    nvm, same pcm as a vx but no easy check codes with the cel it seems.
  14. edals
    Here
    VE Equipe
    VY doesn't work like that. You need a aldl scanner. Unless I've missed something completely.
  15. REED1E
    REED1E New Member
    In my commodore book, your right, it says only a series 1 vt you can bridge, everything else you need a scan tool
