Help needed with engine swap
h8tensv6
Newcastle NSW
2009 SV6 2002 VX 1989 VN 5 Litre
Hey guys im posting this for my brother that’s doing the swap.
Hey people im looking for some help, Iv put a known running 3.6 10h9h engine from 1/07 4wd auto, into a 9/07 2wd manual, that originally had a 10h9e in it, and it wont run.
I can crank it over and over without generating any error codes, if i disconnect the cam sensor it will start, rev to 4 grand and shut down, and generate a code for cam sensor fault, plug it back up and wont start......
i was told to swap the cam reluctors of the original motor onto this one, read they should prise off the gear, but i cant get them off, I have belted the **** out of them but no luck. Is my only option to remove the gears and swap them over. Anyone have any ideas, cheers......
_R_J_K_
Zenki S14
Just swap the cam sensors themselves. You may also have to swap the crank angle sensor too.
