help no matter wat the air comes out on windscreen
vlwrecker
vt clubsport n vl turbo
hey guys just got a vt clubby n no matter wat i put the ac or the options eg face feet ot wat ever i put it on it comes out at the windscreen wat could be the prob thanks
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
It might have something to do with the vacuum. Check the thin vacuum hose at the rear of the intake manifold.
vlwrecker
yer it was off but is now back on n still no change
accentstencil
68
Eschol Park, Sydney
There should be a round plastic valve there as well, check that it is working, you should be able to blow through it one way but not the other way.
vlwrecker
yer the valve is right but still cant control the area everythink is windscreen
accentstencil
68
Eschol Park, Sydney
Do you have climate control or standard A/C?
vlwrecker
standard a/c
pittin
VN Executive S2
ive got exactly the same prob in my VT Acclaim, there is a hissing behind the glovebox, i assume there is a vacuum connection there? and my fan only works on level 1,2 and 3 when its on max it stops? would the resistor be gone in the fan? time for a new one?
Cobez
LS-EXUAL
2004 S2 VY SS Ute
I had this problem on my old car (VP). I'm not sure if VT's have them, but my VP had a long steel rod that is connected to the back of the dial you turn to change it between feet / vents / dash etc. The bit that the end of that clipped into was broken (the little plastic clip down near where your left foot would sit on the footrest.
