yer i do have a hissing behind the glovebox as well
V vlwrecker New Member Joined May 31, 2009 Messages 11 Reaction score 0 Points 0 Members Ride vt clubsport n vl turbo Jun 8, 2009 #11 yer i do have a hissing behind the glovebox as well
Cobez LS-EXUAL Joined Feb 22, 2007 Messages 3,109 Reaction score 42 Points 48 Age 39 Members Ride 2004 S2 VY SS Ute Jun 9, 2009 #12 There is a vacuum hose that runs from the back of the heater control to up behind the glovebox. Pull your glovebox lid off and you should be able to find it. That might be loose or completely disconnected.
V vlwrecker New Member Joined May 31, 2009 Messages 11 Reaction score 0 Points 0 Members Ride vt clubsport n vl turbo Jun 11, 2009 #13 yer found prob it was a hose off on the fan bit like said above thanks to all ya help
M mrcommy New Member Joined Jun 13, 2009 Messages 4 Reaction score 0 Points 0 Members Ride VX Executive S2 Jun 13, 2009 #14 check ur vaccum lines. the actuator uses vaccum to change the the flap setting so it can blow to the face feet or wateva. first check to see in the engine bay on the passenger side if all the vaccum lines are hooked up
P pittin New Member Joined Aug 28, 2007 Messages 2 Reaction score 0 Points 0 Members Ride VN Executive S2 Jun 13, 2009 #15 yeap i found it, behind the glovebox, everything works now except the fan, only works on 1 2 and 3, just turns off on max.
