im removing my engine like i said. but.. im disconnecting the a/c and the bolts that hold it hit the chassis as i pull them out because of there length. i managed 1 bolt out but the other 3 are impossible. i need some tip on getting them out. i was thinking to raise my engine a bit until the bolts sit out past the chassis and then undo them. is that the way its done or???? any advice asap would be appreciated. heres a picture.
not sure, i dont have A\C, you may want to have a check of the "How to" forum. i could imagine what you said would work if you require the extra height, why dont you just remove the pump when you take the motor out?
that black condenser thing at the top? well its bolted in and goes through into the dash or sumthin so i dont know? i think i can manage to get it off tho i might have figured it out. i just need to disconnect my trans now. needa figure out how to do that so i might go get a gregories manual now. or if anyone could put some info in and save me some time that would be sweeeet. cheers
