HELP! - Overheating issue
FATASS
Wollongong
Vy Berlina
Hi All
So, I was jsut driving to get some lunch, was stuck at some lights & the engine hot warning came on. I pulled over for a few minutes and let it cool down, then drove another 2 minutes back to work.
By the time I got back to work I heard a hissing noise, popped the bonnet and found coolant leaking out - couldnt tell exactly where. Had to get back into office so locked her up and left.
its a pretty hot day ~30 degrees.
Im thinking that a hose has split due to heat? or could it be something worse like a blown radiator?
Any pointers would be appreciated. Will it be safe to drive once cool? Or should I call a tow truck?
colgf
s/charged v6 HR Holden, s/charged v6 EH Holden,
You have probably got a split radiator side tank , these are plastic & best to replace with a new radiator , about $200 plus labour to fit, suggest you refill it when cooled down then take it drive carefully keep eye on warning light to nearest repair shop, not wise to drive it in this weather , could damage the engine /blow head gasket, etc etc .
vk.jonno
south east
Vk commodore, hq one tonner, hj ute,
u needa try find where the leaks coming from...
like hoses..
if its a hose u can just replace it
FATASS
Wollongong
Vy Berlina
Thanks guys, its going to be a long afternoon...
Is there a specifit coolant I need to refill with?
Sean880
VIC / NSW
2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
Is there a specific coolant I need to refill with?
Yes for the V6 engine use Castrol "Anti-Freeze 350 Coolant Concentrate" which is the correct spec coolant and meets the Holden spec HN 2043. It's a concentrate to be diluted 50/50 mix with distilled/de-mineralised water (like Glendale distilled water). (Nulon also have a coolant concentrate product that meets Holden spec HN 2043 for the V6 engines. ) This coolant spec is covered in your owner's manual.
Don't use a product that does not comply and it is unwise to mix different brands of coolants (according to the manufacturers of these products).
When the leak problem is fixed flush the whole cooling system with water , fill with fresh coolant mix and ensure the system is well bled of air using the bleed screws. You should also purchase the coolant pellets from Holden and add these to the coolant when filling the system. You simply crush 3 of them into powder form in a plastic bag (with a hammer) and add it to the radiator fluid. (When filling the system don't forget to top up the overflow reservoir to the correct level. Preferably this reservoir should be removed and cleaned out). After flushing the system there will be some clear water remaining in the system so ensure you increase the coolant concentrate proportion to compensate for this. Otherwise the fluid mix will be too diluted.
Burnout124
Western Australia
VY Executive S2/ VY SS 6sp
Don't forget the thrermostat i cold be faulty and you should replace it if you have overheated your car.
maccasparks
Tauranga NZ
VY V6 Wagon
I'd just fill it with water until you get the leak / problem sorted out then use the correct mix
FATASS
Wollongong
Vy Berlina
Topped up with water and managed to get home - its definitely a crack in the radiator
Will get a quote on a new radiator tomorrow
Thanks for all the help lads!! This is why I love this forum
colgf
Not a problem , seeing you have to pull the radiator out you might as well change the hoses too , also try & buy a Heavy Duty radiator , they have a 16mm wide core instead of the piddly 11 mm standard core , not that much dearer either.
FATASS
Wollongong
Vy Berlina
Any recommendations on where to buy & brands?
Calsonic any good?
