HELP pacemakers have made car run lumpy and backfire
Discussion in 'V6 Development And Modification' started by erugby, Jan 14, 2008.
  1. erugby
    erugby New Member
    VX Wagon V6 S2
    Hey everyone i just got pacemakers fitted to my vx v6 and its sounding really lumpy and backfires a lil when i plant my foot until it reaches about 3000rpm then it roars and sounds great!
    is this normal?!
    when i baby it it doesnt sound lumpy or even if i baby it to 1500-2000 rpm then floor it. But if i floor it from stationary it will shudder a bit and struggle to get moving then it'll reach 3000 and go
    i dont think its engine issues because the engine has never had any other problems and has only done 65000 k's
    the only engine mods are the pacemakers into metal high flo cat into 2.5" catback with no rear muffler
    help!!!!,
    my car sounds dodgy and when i do plant it from 0 it feels like its tearing the zorst apart
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    change your spark plugs.... cos if you cracked one or 2 of them it will run badly....
  3. cxcxcxvcvcvc
    cxcxcxvcvcvc Active Member
    The Plains
    VT Commodore
    bet its a leaking exhaust gasket! the reason it will be running rough is because it has a loss of back pressure @ idle whereas once it opens up the leak will allow the gasses to escape quicker and thats why it sounds good and probably goes good to:D
  4. erugby
    erugby New Member
    VX Wagon V6 S2
    it could actually be the gasket, i'm taking it back 2moro to get them to check it out. i'll update then
    thanks mate :)
  5. Commotion
    Commotion New Member
    beenleigh
    04 WRX
    it sounds like the o2 sensors are giving wrong readings. check the smell of the exhaust at idle. they usually smell a bit fuelly, if not then its the same problems i had with mine. new o2 sensor fixed mine.
  6. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Check that the leads have been put back correctly.
  7. Stretchomatic
    Stretchomatic Member
    Ardlethan, NSW
    86 VL Berlina M5
    id probly just start and idle for 10 secs or so to reset the ecu, never hurts to try, even after my clutch was replaced the car ran wierd.
  8. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Disconnecting the positive battery terminal for 10 seconds will reset the ECU.
  9. erugby
    erugby New Member
    VX Wagon V6 S2
    cheers mate :)
    i pushed all the leads in and reset the ECU and its running great now
    thanks heaps everyone :)
