Help please - Airbag light on
talmid
54
Sunshine Coast
VZ SV6
Hi, just purchased car has the airbag light on. Safety Cert mechanic checked and said fault is open circuit on drivers and passengers front airbags. Told need to replace both airbags. 2006 VZ v6. Any advice appreciated, thanks
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
I'd be looking at the clock spring first. That will give the same error. After replacing the clock spring, you will need to reset the light with a scan tool.
gossie
Gold Coast.
VE International 3.6L
Why would you buy a car with no RWC?
_R_J_K_
Zenki S14
Another super helpful response that directly addresses the problem at hand.
Could be for any number of reasons - i.e. came from interstate where they don't need to be sold with one (and even if they did, the interstate cert wouldn't count for anything anyway).
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
There is no such thing as RWC in Qld.
A Safety Certificate is required only if the vehicle is sold registered
Not an Abba Fans reply works for me as I have seen this same thing before.
