help please guys
fordsuck
vr commodore
hi all, i am trying to replace the tranny on my v6 vr commy & have run into a problem. I cant get the torque convertor housing cover off, i have removed all the bolts i can see & it seems loose but it doesn't have the clearance to come off. My question is what else do i have to remove?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Have you taken the starter motor out?
fordsuck
vr commodore
no still on, just been following my ellerys book & it doesn't mention anything about removing the starter motor.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Unless the cover has a slot in it where the starter bolts to it, then it has to come out.
DannyboyDS
Just hand me the pliers.
VS Berlina
what about the brackets either side of the cover? they go from the trans to the engine block, at least one of them will have to come off to remove the cover, and well, both if you plan on removing the transmission.
fordsuck
vr commodore
can't see any brackets, the cover looks like a 1 piece casting with 4 x 15mm bolts "cover to auto" & 6 x 13mm nuts on studs " cover to engine". the studs on the engine seem to be stopping the cover from coming off.
fordsuck
vr commodore
Does anyone have any ideas ??????????????:supersad:
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
You might have to pull the studs out then. Lock two nuts together on the thread then undo them.
