HELP PLEASE... leaking oil
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Pezz44, Sep 28, 2008.
  1. Pezz44
    Pezz44 New Member
    VS executive
    Hey i'm a bit of a novice here, i hav a VS commodore, but i have an oil leak coming from just above the oil filter. There's a clip of wires just above the filter, which i can only guess are to do with the oil gauge?? but anyway yer its leaking oil pretty bad... so was wondering should there even be oil there in the first place? can i replace the fitting? do i need the wires attached, or can i live with out the warning light and fill the leak? any help would be greatly appreciated... as to wat these wires are and how i can fix this stoopid leak. thanks
  2. gendi
    gendi Member
    Cessnock, NSW
    06 VZ SVZ Wagon
    could be power steering fluid.
  3. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
    the thing with the wires is the oil pressure switch. easy screw out/screw in replace.
    pretty sure it won't run without the wires connected as it thinks there's no oil pressure (safety feature) but i could be wrong
    but as gendi said, it could be leaking power steering pump also. what colour is the fluid? if it's red it's steering fluid, if it's brown it's oil
  4. r_i_d_a_h
    r_i_d_a_h New Member
    '97 VS Commodore + '98 E36
    in my thoughts, its most likely power steering fluid, just go and buy power steering leak fix fluid and see how yoo go after a few days.
  5. Cheap6
    Cheap6 New Member
    VP Exec
    If there is any doubt about the source of the leak, wash clean - degreaser is best but dishwashing liquid pre-mixed in a spray bottle works (and smells lovely, keeps you hands soft...) - drive and look again. The area needs to be clean before opening up the oil system, even just to replace the switch, anyway.
    The car will run and start normally with the switch disconnected.
  6. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I always thought the fuel pump gets its power thru the oil pressure switch so in theory no oil pressure = no fuel pressure = no go. Designed this way so if you have a prang and the engine stalls the fuel flow stops plus if no oil pressure due low oil the fuel pump stops to prevent engine damage.
    Which is correct?
  7. Cheap6
    Cheap6 New Member
    VP Exec
    I think that it's covered in the other (concurrent) thread.
  8. greenacc
    greenacc Searching for the billion
    VE Berlina
    I reckon its the power steering pump, mine does the same thing. Wipe your oil filter clean and check it after a few days. If there is red oil on it its from the PS pump above.
    From memory the fule pump is wired through 2 circuits in case one fails so you can still drive. The oil pressure switch is the secondary one.
  9. kopper69
    kopper69 New Member
    VRII Acclaim
    The oil pressure switch only comes into play if the fuel pump relay isnt working. If the relay doesnt work, power is supplied through the oil pressure switch but the oil must first be up to pressure for the switch to close - which means extended cranking until the oil is up to pressure. Gregorys gives a better detail of what happens if youre interested. The car will run without the switch (assuming the fuel pump relay is working) but you will get the oil light on.
    If the car relied on the oil pressure switch to start, you would be cranking for several seconds everytime you wanted to start the car waiting for the oil to come to pressure. Although I do like the idea that you have mentioned about the engine dieing if there was low oil pressure - maybe the ECU, which is tied in the system, monitors and takes care of this if it finds that the oil pressure is low for a preset amount of time?
  10. Pezz44
    Pezz44 New Member
    VS executive
    thanks guys. yer its definately oil, and definately comin through the oil pressure switch thing... so i guess a trip to the wreckers or somewhere is needed. i thought it may hav been power steering fluid myself, but definately oil.
  11. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Buy a new one as they're under $20 new.
  12. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Hmmmm...Gregorys says that when you turn the ignition on the ECU powers the fuel pump for 2 seconds (to prime the fuel lines and allow car to start) Once the engine is running the oil pressure switch closes and supplies power to the pump thru the normally closed section of the fuel pump relay. The wiring diagram on page 105 indicates that if there is no oil pressure the fuel pump relay cannot be powered by the oil pressure switch as its open circuit when no oil pressure exists.
  13. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    Last i heard the fuelpump relay was just to prime with(or 5 sec), it cuts out after engine starts and oil pressure switch takes over.
