Help please!! VT SS have no engine spark?
lunardox
vt ss 5 speed
Went to start the car one morning and went to fire up, let go of ignition to early and stalled, now it wont fire up just keep's turnig over. Have checked all fuses and relay's, has spark from coil to dizzy but does not continue through the leads, checked dizzy to see if the rotar button was still turning and everything is fine, also checked computer and just say's everything is normal. Anyone that could help i would greatly appreciate. Thanks
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Is the security light in the mode switch flashing while it's trying to start?
lunardox
vt ss 5 speed
No the light is not flashing while i try starting it. the engine turns over but wont fire.
BlackVXGTS
Melbourne, SE
Replace your ignition module. Silver box that sits on the passenger side guard.
bandit10
VE SS
if you have spark from coil to dizzy then it must be your dizzy cap or rotor or leads stopping the spark from getting to the plugs.
If the ignition module or coil was stuffed you would get no spark from coil to dizzy
lunardox
vt ss 5 speed
dizzy cap is still good, ignition coil is working, i think it may be the module in the dizzy? also rotor button still spinning. thanks for all the post's. process of elimination unfortunately
lunardox
vt ss 5 speed
sorry i mean the ignition module is still working. thanks bandit for the heads up on that one.
