heno
Hi There,
Have been everywhere trying to find an answer but nothing yet.
I have a VT, all stock, 1999. Just a runabout to and from work.
Has an automatic transmission.
In the 2 high gears, at low revs, there is a low pitched hum or growl and a slight vibration coming from the engine.
It kicks in at 53kmph and 1000rpm and leaves at 58kmph / 1250rpm and also comes again at 76kmph / 1000rpm and leaves at 80kmph / 1250rpm.
If you accelerate smoothly up to 85 then it does not happen at all. Only happens when you gradually get up to cruising speeds and as it drops into the next gear, it happens.
Does not happen at all in first 2 gears. Does not seem to affect performance at all.
Any help would be great!
