Help - POWERTRAIN fault
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Vzwagon07, Jul 19, 2012.
  1. Vzwagon07
    Vzwagon07 New Member
    Vz commodore
    I have a VZ Commodore wagon on factory LPG, when staring cold it spits and coughs and often the check POWERTRAIN light comes on. When the mechanic checked it he said coil 4 needs replacing, this didn't fix my problem.
    I've noticed this is a common problem and by the sounds of it everyone seems to try numerous things and nothing fixes it.
    Has anyone had the same problem and had it fixed. I have also had the plugs changed, please help.
  2. leethal1
    leethal1 New Member
    Perth Australia
    2005 Adventra LX6, HG monaro
    I have never worked on the factory system, does your car start on petrol and change over to LPG when warm? if so how does the LPG run?
