help! problem!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Beav, May 18, 2012.
  1. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Well I ####ed up and I know I have do please no stupid comments.
    Ok I securing subwoofer into the boot of my car, some how I have managed to hot the fuel tank! :( how bad is this? Is it an easy fix?
    I found this out when I was driving I could smell fuel so pulled over and lifted the carpet in boot and sure enough there was some fuel!
  2. Shooter03
    Shooter03 Nek Minnit
    Narre warren
    Vz wagon
    lol a mate of mine did the exact same thing, there's no easy fix you gotta drop the tank and patch it up or the fuel vapors can get pretty dangerous.
  3. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Hey do you drop the tank
  4. Shooter03
    Narre warren
    Vz wagon
    take all the lines off and i'm pretty sure its held up by a couple of straps. this was on a vk at the time. might be different on a newer car, just be prepared for a bit of work.
  5. Beav
    Beav New Member
    Emerald
    93 vr commodore
    I get under tomorrow and have a look.
    Could I just weld a piece of flat bar on?
    I filled the tank up with fuel on Wednesday night and have hardly driven it, it's a full tank
  6. *uwishn*
    *uwishn* Holden special vehicles
    sydney
    vl walkinshaw(replica)nissan navara d40 st-x turbo
    very easy to take a vr tank out really,just replace it,there cheap too.
    buy a siphoning hose and save your fuel??
  7. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Ill have a look. Where could I get a tank? Wreckers?
  8. SavVYute
    SavVYute Active Member
    VY S V6 Ute Series II 2004
    Don't even think about welding it Beav unless you know what you're doing.
    I will blow up and kill you.
  9. VR38
    VR38 Well-Known Member
    VB SL/E
    Solder it with one of those large soldering irons.
  10. Beav
    Beav New Member
    Emerald
    93 vr commodore
    I'd only weld it when it's emptied and cleaned out but still a chance hey.
    It's only a small hole so soldered over the hole
  11. drewVHSS
    drewVHSS Donating Member
    Gosford Central Coast
    '83 VH SS, '79 Green VB SL '92 S2 VQ Caprice
    Still not worth welding, i've seen tanks washed out and then welded and residual fumes still managed to make the tank swell up.
    Far safer and hassle free to just buy another tank and be done with it.
  12. SavVYute
    You can get a fuel tank repair kit from most auto places.
    About $30. Epoxy that's fuel resistant.
    I'd even think twice about soldering it!
  13. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    either replace it or
    get a big soldering iron, 80-120 watt (something with a tip about half the size of a broom handle, you'll need lots of heat to combat the heat sink capabilities of the tank), DO NOT try to weld it or use a flame near it, even when empty, it's not the liquid fuel that's dangerous, it's the vapor that's flammable and explosive.
  14. VR38
    VB SL/E
    Or beg or borrow or buy from the markets one of the older irons with the block of copper on the end that you heat on the stove.
  15. showbags
    showbags SENIOR EL'BAGO
    VT Calais, BMW 135 m sport
    FFS don't put any heat source near that tank!!! Either use fuel resistant epoxy or buy another tank.
  16. Beav
    Beav New Member
    Emerald
    93 vr commodore
    I'll check out a fuel tank repair kit tomorrow then thanks
  17. VR38
    VB SL/E
    Yeah you are right, we better disconnect our rear brakes and plumb our exhaust pipes out the front of the car instead of the rear... scardy cat.
  18. Jxfwsf
    Aus
    commodore
    depends on the heat source, i've soldered quite a few fuel tanks in the past using a large 80 watt soldering iron and the repairs worked well with no ill effects, scariest thing was using this beast as i'm pretty sure it's over 40 years old lol
  19. PROBLEM?
    PROBLEM? umadbro?
    AUSTRALIA
    commo
    hahahaha,fully sick sub woofer
  20. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Yer subwoofer is good. It's set well, you can still hear the song it's not just all doof doof.
